5.4.1.2.11.2.9. STRUCT_SIMOCODE_PRO_EVENTS
OVERLOAD_OPERATION
BIT
[128] Event - Overload operation
UNBALANCE
BIT
[129] Event - Unbalance
OVERLOAD
BIT
[130] Event - Overload
OVERLOAD_PHASE_FAILURE
BIT
[131] Event - overload + phase failure
INTERNAL_GROUND_FAULT
BIT
[132] Event - Internal ground fault
EXTERNAL_GROUND_FAULT
BIT
[133] Event - External ground fault
WARNING_EXT_GROUND_FAULT
BIT
[134] Event - Warning ext. ground fault
THERMISTOR_OVERLOAD
BIT
[135] Event - Thermistor overload
THERMISTOR_SHORT_CIRCUIT
BIT
[136] Event - Thermistor short-circuit
THERMISTOR_OPEN_CIRCUIT
BIT
[137] Event - Thermistor open circuit
TM_WARNING_T_G
BIT
[138] Event - TM warning T>
TM_TRIP_T_G
BIT
[139] Event - TM trip T>
TM_SENSOR_FAULT
BIT
[140] Event - TM sensor fault
TM_OUT_OF_RANGE
BIT
[141] Event - TM out of range
EM_OPEN_CIRCUIT
BIT
[142] Event - EM+ open circuit
EM_SHORT_CIRCUIT
BIT
[143] Event - EM+ short-circuit
WARNING_I_G
BIT
[144] Event - Warning I>
WARNING_I_L
BIT
[145] Event - Warning I<
WARNING_P_G
BIT
[146] Event - Warning P>
WARNING_P_L
BIT
[147] Event - Warning P<
WARNING_COS_PHI_L
BIT
[148] Event - Warning cos phi<
WARNING_U_L
BIT
[149] Event - Warning U<
WARNING_0_4_20_MA_G
BIT
[150] Event - Warning 0/4 - 20 mA >
WARNING_0_4_20_MA_L
BIT
[151] Event - Warning 0/4 - 20 mA <
TRIP_I_G
BIT
[152] Event - Trip I>
TRIP_I_L
BIT
[153] Event - Trip I<
TRIP_P_G
BIT
[154] Event - Trip P>
TRIP_P_L
BIT
[155] Event - Trip P<
TRIP_COS_PHI_L
BIT
[156] Event - Trip cos phi<
TRIP_U_L
BIT
[157] Event - Trip U<
TRIP_0_4_20_MA_G
BIT
[158] Event - Trip 0/4 - 20 mA >
TRIP_0_4_20_MA_L
BIT
[159] Event - Trip 0/4 - 20 mA <
STALLED_ROTOR
BIT
[160] Event - Stalled Rotor
WARNING_INTERNAL_GROUND_FAULT
BIT
[161] Event - Warning internal ground fault
NO_START_PERMITTED
BIT
[163] Event - No start permitted
NO_OF_STARTS_G
BIT
[164] Event - No. of starts >
JUST_ONE_START_POSSIBLE
BIT
[165] Event - Just one start possible
MOTOR_OPERATING_HOURS_G
BIT
[166] Event - Motor operating hours >
MOTOR_STOP_TIME_G
BIT
[167] Event - Motor stop time >
LIMIT1
BIT
[168] Event - Limit 1
LIMIT2
BIT
[169] Event - Limit 2
LIMIT3
BIT
[170] Event - Limit 3
LIMIT4
BIT
[171] Event - Limit 4
EXTERNAL_FAULT1
BIT
[172] Event - External Fault 1
EXTERNAL_FAULT2
BIT
[173] Event - External Fault 2
EXTERNAL_FAULT3
BIT
[174] Event - External Fault 3
EXTERNAL_FAULT4
BIT
[175] Event - External Fault 4
EXTERNAL_FAULT5
BIT
[176] Event - External Fault 5
EXTERNAL_FAULT6
BIT
[177] Event - External Fault 6
ANALOG_MODULE_OPEN_CIRCUIT
BIT
[180] Event - Analog module open circuit
DM_F_SAFETY_RELATED_TRIPPING
BIT
[181] Event - DM-F safety-related tripping
DM_F_TEST_REQUIREMENT
BIT
[182] Event - DM-F - Test requirement
TIMESTAMPING_FUCTION_ACTIVE
BIT
[184] Event - Timestamping function active + OK
DM_FL_SAFETY_OK
BIT
[186] Event - DM-FL safety o.k
DM_FP_PROFISAFE_ACTIVE
BIT
[187] Event - DM-FP PROFIsafe active
CONFIGURED_OP_MISSING
BIT
[188] Event - Configured operator panel missing
